zamek centralny?
WJ Jeep
Post autor: WJ Jeep » pt wrz 02, 2005 10:48 am
Radek666 pisze:
Stiopa pisze:
Radek666 pisze:Kup sobie komplet drzwi z bebechami na jakims szrocie i przeloz ;-)
@Radek - widzę , że masz dzisiaj od rana same dobre pomysły . :)21 :)21
Energia aż Cię roznosi . :D :D Co Ci sie takiego miłego w nocy przydarzyło , żeś taki kwitnący ? :D :D :D
No coz - zona sie niewatpliwie do tego przyczynila ;-)
A co, w końcu raz po pracy wróciła trzeźwa do domu z całą wypłatą i w dodatku nie biła ? :)21
WJ '00 6.5"
Radek666
Post autor: Radek666 » pt wrz 02, 2005 10:55 am
WJ Jeep pisze:
A co, w koñcu raz po pracy wróci³a trze¼wa do domu z ca³± wyp³at± i w dodatku nie bi³a ? :)21
Nie to bylo dokladnie tak;
TReneR wakes up with a huge hangover after attending his company's
party. He is not normally a drinker, but the drinks didn't
taste like alcohol a bit. He didn't even remember how he got home from
the party. As bad as he was feeling, he wondered if he did something
wrong. TReneR had to force himself to open his eyes, and the first thing
he sees is a couple of aspirins next to a glass of water on the side
table. And, next to them is a single red rose!
He sits up and sees his clothing in front of him, all clean and
pressed. He looks around the room and sees that it is in perfect order,
spotlessly clean. So is the rest of the house. He takes the aspirins,
cringes when he sees a huge black eye staring back at him in the
bathroom mirror.
Then he notices a note hanging on the corner of the
mirror written in red with little hearts on it and a kiss mark from his
wife in lipstick. "Honey, breakfast is on the stove. I've gone to get
groceries t o make you your favorite dinner tonight. I love you,
darling! Love, Wife"
He stumbles to the kitchen and sure enough, there is hot breakfast,
steaming hot coffee, and the morning paper. His son is sitting at the
table eating. Jack asks, "Son, what happened last night?"
"Well, you came home after 3 AM, drunk out of your mind. You fell over
the coffee table and broke it, then you puked in the hallway, and got
that black eye when you ran into the door."
Confused, TReneR asked his son, "So why is everything in perfect order,
so clean,
I have a rose, and breakfast is on the table waiting for me?"
His son replies, "Oh THAT! Mom dragged you into the bedroom, and when
she tried to take your pants off, you screamed, "Leave me alone, lady,
I'm married!"
Broken Coffee Table...$239.99
Hot Breakfast...$4.20
Two aspirins...38 cents
Saying the right thing, at the right time...Priceless.
Radek zwany TReneR
SławekXJ
Post autor: SławekXJ » pt wrz 02, 2005 10:56 am
WJ Jeep pisze: A co, w końcu raz po pracy wróciła trzeźwa do domu z całą wypłatą i w dodatku nie biła ? :)21
:)2 Dobre
Ale swoją drogą jak facet myśli o uszczęśliwianiu przez żonę to jest to albo seks albo wyprowadziła się do mamy (w zależności od stażu małżeństwa)
SławekXJ
Post autor: SławekXJ » pt wrz 02, 2005 10:58 am
Radek666 pisze: Nie to bylo dokladnie tak;
TReneR wakes up ...
:)21 :)2
WJ Jeep
Post autor: WJ Jeep » pt wrz 02, 2005 11:02 am
@Radek Widzę, że zwą Cię nie tylko TReneR, ale i Jack :D
Opowieść bardzo pouczająca :)2 :)2 :)2
WJ '00 6.5"
Radek666
Post autor: Radek666 » pt wrz 02, 2005 11:28 am
WJ Jeep pisze:@Radek Widzê, ¿e zw± Ciê nie tylko TReneR, ale i Jack :D
Aj no jeden Jack sie zaplontal.... :)2 :wink:
Radek zwany TReneR
pezet
Post autor: pezet » pt wrz 02, 2005 11:31 am
intruz pisze:A czy ktos z was koledzy ma doswiadczena z montarzem sterowania i silownikow do jeepa, ktory nie byl wyposazony w centralny zamek. Tak sie zastanawiam, czy wystarczy zakupic uzywane silowniki i podpiac je do instalacji i do zamkow, czy wymaga to wiekszych przerobek?
Podobny problem nurtuje mnie w przypadku elektrycznie sterowanych szyb...trafil mi sie kurna goly jeep...
Z tego co widze na Allegro to komplet silownikow z pilotami kosztuje 70zl, wiec moze nie warto szukac uzywek od jeepa?
Adamek
Post autor: Adamek » ndz wrz 04, 2005 11:08 am
Radek666 pisze:
A przynajmniej zonie się spodobało ?? :lol:
SławekXJ
Post autor: SławekXJ » pn wrz 05, 2005 7:53 am
Adamek pisze:
Radek666 pisze:
:)2 :lol: :lol: :lol:
klimson
Post autor: klimson » wt wrz 06, 2005 2:48 pm
Adamek pisze:Odbiornik masz wyżej lustera centralnie na śroku, zdejmij tą przysłonke i znajdziesz w środku , bez problemu wysuniesz całą płytkę. Tam masz tak, że pilotem dajesz sygnał do tego odbiornika, a on powoduje zwarcie i otwiera zamki w drugą strone jest tak samo, jak wyjmiesz i odepniesz płytke z kostki mozesz to zobaczyć zwierająć na ostro , na dwóch zamyka a na innych otwiera. Poszukam jeszcze gdzieś kompletu, bo gdzieś mi się walał tylko musze sprawdzić co i jak i dam znać.
zdjalem konsole i tam jakby z fabryki wyjechal az szkoda ta plytke wywalac :-? i raczej przekaznikow nie widze- czy to znaczy ze sa ale gdzie indziej i mam zakupic sterownik bez przekaznikow? widze 6 kabelkow w roznych kolorach i jakos strach tak zwierac na czuja... :-? moze jaki schemat ktory do czego zebym czegos nie sp...lil ??
>>>nie rzucim ziemi skad nasz ROOT<<<
IROKEZ 1991, XJ 4.0L HO Limited mod.1992, LPG IIgen.
Adamek
Post autor: Adamek » wt wrz 06, 2005 2:59 pm
Nic nie spalisz, weź kawałek kabelka i zwierasz w kostce jak otwiera a na 100 % otworzy to masz przekaźniki gdzieś gdzie ich nie widać, sam nie wiem gdzie one są.
klimson
Post autor: klimson » wt wrz 06, 2005 3:05 pm
poniewz jest 6 kabelkow a 4 zamki i po 2 opcje na kazdy( zamknij i otworz) to wszystko jedno co zwieram ?? i tak az do skutku, do ustalenia ktore sa od czego ??
Radek666
Post autor: Radek666 » wt wrz 06, 2005 3:07 pm
klimson pisze:poniewz jest 6 kabelkow a 4 zamki i po 2 opcje na kazdy( zamknij i otworz) to wszystko jedno co zwieram ?? i tak az do skutku, do ustalenia ktore sa od czego ??
No chyba ze akurat trafisz na mase i zasilanie modulu... wtedy otwozysz bezpiecznik ;-)
Radek zwany TReneR
klimson
Post autor: klimson » wt wrz 06, 2005 3:14 pm
Radek666 pisze:
no :lol: :lol: i dlatego moze cos o kolorach :wink: ?? masa i to drugie a ..zasilanie to jakie maja kolory ??
Adamek
Post autor: Adamek » wt wrz 06, 2005 3:18 pm
Jakie cztery o klapie bagaznika zapomniałeś :D , ale to nie ma znaczenia bo jeden obwód zamyka a drugi otwiera.
Radek666
Post autor: Radek666 » wt wrz 06, 2005 3:37 pm
Wiec tak;
Przekazniki masz ponizej/za "glove boxem". Dwa ostatnie w kolumnie.
Przekazniki sa sterowane plusem - wiec jezeli modol steruje tylko minusem to bedziesz musial przelaczyc mase przekaznikow na plus. Lub tez kupic modol z przekaznikami lub tez mozliwoscia sterowania plusem.
Poza tym najprosciej jak mozesz sprawdzic ktore kable sa od sterowania przekaznikami to wziasc ohmomierz w lape .......
UNLOCK - rozowo/fioletowy
LOCK - pomaranczowo/fioletowy
GND - czarny
ACC - pewnie czerwony lub bialo/czerwony
Pozostale dwa to sygnal o zamknieciu do alarmu (wersja z konsola poddachowa) i sygnal do wlaczenia oswietlenia wewnetrznego po otworzeniu.
Radek zwany TReneR
Adamek
Post autor: Adamek » wt wrz 06, 2005 5:16 pm
No i wszystko jasne....... :lol: :lol: :lol:
klimson
Post autor: klimson » wt wrz 06, 2005 5:28 pm
Radek jak zwykle mi zaimponowales :lol: o ile rozumiem to jesli nie mam modolu sterowanego plusem ( a wlasciwie, w pipie to masa jest....plus ?? ) to podlaczenie takiego z przekaznikami sprowadzi sie do tego ze owe przekazniki steruja tymi za schowkiem na rekawiczki :wink: ?
Radek666
Post autor: Radek666 » wt wrz 06, 2005 9:50 pm
klimson pisze:Radek jak zwykle mi zaimponowales :lol:
A pronciem bardzo ;-)
klimson pisze: o ile rozumiem to jesli nie mam modolu sterowanego plusem ( a wlasciwie, w pipie to masa jest....plus ?? ) to podlaczenie takiego z przekaznikami sprowadzi sie do tego ze owe przekazniki steruja tymi za schowkiem na rekawiczki :wink: ?
No w peepe masa to minus ;-) - to nie jest ruski samochod.
Sterowanie "plusem" oznacza tu ze drugi koniec cewki przekaznika jest dolaczony do masy a impuls sterujacy ma poziom aktywny +12V.
Modol z przekaznikami - dokladnie tak jak napisales.
Wiekszosc modolow ma ocje sterowania masa lub plusem - lub tez latwo mozna je zmodyfikowac...
Radek zwany TReneR
belfer
Post autor: belfer » pn lis 21, 2005 12:10 pm
Ja także chcę założyć od podstaw cz i w związku z powyższym mam pytanie:
Czy polecacie bądź odradzacie jakąś firmę z tych tańszych i ile kg uciągu powinien mieć siłownik ??
Cherokee XJ 4.0 96'
Comanche MJ 4.0 88'
Wróć do „Jeep”
