prosty dekoder VIN dla pojazdów Land Rover i Range Rover
: ndz wrz 14, 2008 12:26 pm
Może sie przyda, może nie było
4th & 5th digits - line
LB Series III
LD 90 & 110
LH Range Rover Classic
LJ Discovery
LM Range Rover L322
LP Range Rover P38A
6th digit - wheelbase
A 88" Land Rover
100" Range Rover
B 108" Range Rover Classic
C 109" Land Rover
G 100" Discovery
H 110" Land Rover
M custom
V 90" Land Rover
7th digit - body type
A pick up, hood cab, truck, or hard top
B 2-door station wagon
88" 90" & Range Rover
2-door Discovery
H high capacity pick up
M 4-door station wagon
R Moneverdi Range Rover
8th digit - engine
B 2.5L turbo diesel
C 2.5L diesel
D 2.5L gasoline
E 2.4L VM turbo diesel
F 2.5L TDI turbo diesel
G 2.25L diesel
H 2.25L gasoline
J 4.6L EFI gasoline
L 3.5L EFI gasoline V8
M 3.9L EFI gasoline V8
4.0L EFI gasoline V8
N 2.5L VM diesel
V V8 3.5L standard carburetor
W 2.5L BMW turbo diesel
3 4.2L EFI gasoline V8
EFI = electronic fuel injected
9th digit - transmission
1 4-speed manual; right-hand drive
2 4-speed manual; left hand drive
3 automatic; right hand drive
4 automatic; left hand drive
5 4-speed manual with overdrive; right hand drive
6 4-speed manual with overdrive; left hand drive
7 5-speed manual; right hand drive
8 5-speed manual; left hand drive
10th digit - model year
A all models except:
B Series III CSW
Range Rover Phase II
90/110 face lift to 1987
C 1986 Range Rover
D 1987 Range Rover
E 1988
F 1989
G 1990
H 1991
J 1992
K 1993
L 1994
M 1995
standard model year codes are
used from T (1996) onwards
dane ze strony http://www.angelfire.com/ca/TORONTO/VIN/landrover.html
LB Series III
LD 90 & 110
LJ Discovery
LM Range Rover L322
LP Range Rover P38A
A 88" Land Rover
100" Range Rover
C 109" Land Rover
G 100" Discovery
H 110" Land Rover
M custom
V 90" Land Rover
2-door Discovery
8th digit - engine
B 2.5L turbo diesel
C 2.5L diesel
D 2.5L gasoline
G 2.25L diesel
H 2.25L gasoline
J 4.6L EFI gasoline
N 2.5L VM diesel
B Series III CSW
C 1986 Range Rover
D 1987 Range Rover
E 1988
F 1989
G 1990
H 1991
J 1992
K 1993
L 1994
M 1995
